ellave's avatar
ellave
RBR750 still on firmware V4.6.14.3, auto update doesn't work
Hi, I have a 750 with 1 satellite, just checked my firmware and its on version 4.X.  Auto update is turned up but has never appeared to work.    If I manually update can i go straight to the latest v...
  • ellave's avatar
    ellave
    May 12, 2024
    Thanks, is there some separate password for the satellite?  It doesn't accept the default 'password' or what I use to access orbilogin.com ?
