r1igby
May 27, 2024Aspirant
RBR750 System is dying
I have a RBR750 system with 2-3 RBS750s depending on if they work, and for the most part, it was doing working relatively well. I think it automatically updated the other day to 7.2.6.31 and everythi...
May 27, 2024Guru - Experienced User
Any time I see an issue after a firmware update, I recommend a factory reset and a clean install. By clean install I mean don't install using a backup.
