LittleLight
Jul 07, 2023Aspirant
RBR750 TFTP issue
Looking for some assistance here. Got an RBR750 which is provided by the ISP. The Contract is over and I am trying to flash it to generic firmware. I have done it previously for RBR50 without any is...
LittleLight
You are absolutely right. Surely the tftp is working as nmrpflash appears to be sending the file and while it happens, the router has red light. This means, like you said, the timing needs to be right if one is trying to do it manually. nmrpflash identifies the correct timing and sends the file. I'll give the manual a go but without the switch, it is really fiddly. Thanks for your help though.
Jul 08, 2023Guru - Experienced User
Try NMRPFlash then, as it's supposed to figure out the timing for you and send the file soon as it detects TFTP is up and running.
