OahuOrbi
Jul 20, 2022Aspirant
RBR750 Throttling Bandwidth
I have an Orbi RBR750 and it's been working fine up until recently. Firmware is up to date, however it's throttling my bandwidth and I'm not sure why. Direct connection between modem and computer g...
OahuOrbi
Latest Firmware: V4.6.8.5_2.1.9
EN2251
Hitron Tech
Jul 20, 2022Guru - Experienced User
What is the CAT# lan cable between the modem and router? CAT6 is recommended.
Is Armor or Parental controls enabled on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- OahuOrbiJul 20, 2022Aspirant
No
Yes
Turn on computers and rest of network.Completed the sequence, not helping.
No
- FURRYe38Jul 21, 2022Guru - Experienced User
I would power OFF the ISP modem for 1 minute then back on. Factory reset the RBR and setup from scratch. Turn OFF the RBS for now. Disconnect ALL other devices from the RBR. Setup the RBR from scratch using 1 wired PC and web browser.
Be sure to not enable Armor, SPC or Traffic Meter. Once you complete the setup wizard. Log out of the web page and close the browser.
Run a speed test using Ooklas installable speed test app.
Also try speed testing with a different PC as well to compare results.
