OahuOrbi
Jul 20, 2022Aspirant
RBR750 Throttling Bandwidth
I have an Orbi RBR750 and it's been working fine up until recently. Firmware is up to date, however it's throttling my bandwidth and I'm not sure why. Direct connection between modem and computer g...
Jul 20, 2022Guru - Experienced User
What is the CAT# lan cable between the modem and router? CAT6 is recommended.
Is Armor or Parental controls enabled on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
OahuOrbi
No
Yes
Completed the sequence, not helping.
No
