Sprite31
Jul 28, 2022Aspirant
RBR750 turns to waiting status everyday
Hello all, My RBR750 disconnects to the internet every morning. It shows "Waiting" for "Internet Status" on Orbi WebUI. I will need to click on "Test" button to regain the internet access which ...
michaelkenward
Jul 29, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
