Sprite31
Jul 28, 2022Aspirant
RBR750 turns to waiting status everyday
Hello all, My RBR750 disconnects to the internet every morning. It shows "Waiting" for "Internet Status" on Orbi WebUI. I will need to click on "Test" button to regain the internet access which ...
Sprite31
Hello all,
I will need to click on "Test" button to regain the internet access which is very annoying.
I thought that this could be DHCP leasing related. then I did assign a fixed IP to my router (Advanced->Setup->Internet Setup->Internet IP Address->Use Static IP Address); and ensure the same fixed IP was listed on DHCP reservation List on my modem (Actiontec T3200M).
However, the problem still exsits. Any thoughs?
Btw, RBR750's log is a joke. Nothing there; But I keep getting the following in modem's log: "ICMPv6 RA: ndisc_router_discovery() failed to add default route."
Not sure if this is related to the issue or not.
Jul 29, 2022Guru - Experienced User
The Actiontec T3200M is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
