rayjai
Jun 15, 2022Guide
RBR750 unable to assign IP addresses after reboot
Hi, every time I reboot or unplug my router to move it, all my devices will disconnect and will have an "unable to assign IP addresses" error. I have 48 devices and all of them will not connect. I wo...
Jun 15, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- rayjaiJun 15, 2022Guide
firmware V4.6.8.2 for the router.
I am using a CM600 modem with optimum.
I'm not sure about the distance, but my backhaul is good.
Satellite 1 - 2 is V4.6.8.2
Satellite 3 is V4.6.5.14, it says there's no new firmware for this one.
- FURRYe38Jun 16, 2022Guru - Experienced User
What browser are you using? Try a different browser?
What are you seeing when you trying to set an IP address reservation?
- rayjaiJun 16, 2022Guide
I tried, chrome edge and safari. I don't think it's browser related since I the devices can't connect to the wifi. It says invalid IP address when I try to connect to it.
I'll try the firmware updates.
Factory resets seems to be the only way to fix it. A simple reset doesn't fix it. Some devices will still have trouble connecting but it resolves itself after about a day later.
