rayjai
Jun 15, 2022Guide
RBR750 unable to assign IP addresses after reboot
Hi, every time I reboot or unplug my router to move it, all my devices will disconnect and will have an "unable to assign IP addresses" error. I have 48 devices and all of them will not connect. I wo...
CrimpOn
Jun 15, 2022Guru - Experienced User
rayjai wrote:
Hi, every time I reboot or unplug my router to move it, all my devices will disconnect and will have an "unable to assign IP addresses" error. I have 48 devices and all of them will not connect. I would try rebooting the modem and router with no effect. The only way to "fix" it is to hard reset my router and redo all my settings, but if I ever need to reboot again, it would lose it all.
Are any of these devices connected to the system with Ethernet cable?
Are you a PC or an Apple house? (there is a tool I'd like to suggest that runs on Windows.)
Have you saved a copy of the configuration to your computer?
(This saves enormous time when doing a Factory Reset.)
I spent a lot of time once configuring devices on my computer and forgot to click the "Apply" button. Was really annoyed when it all disappeared.
- rayjaiJun 15, 2022Guide
everything is connected to through wifi only, and I am on PC, android and iphones
I tried the windows troubleshoot and it says it could not resolve the IP.
- tucsonticoJun 16, 2022Virtuoso
The fact that one of your Sats is on a different firmware can be causing your issue. Either downgrade the RBR and Sat 1 & 2 to match Sat 3 or upgrade Sat 3 to match the RBR and Sat 1 & 2. If possible, do the upgrade or downgrade via ethernet. With the problems a lot of folks are seeing with 4.6.8.2, I'd recommend downgrading to 4.6.5.14. After reloading whichever firmware you decide on, do a factory reset on the RBR and Sats, then reconfigure from scratch (or a backup config file). Good Luck!
