rayjai
Jun 15, 2022Guide
RBR750 unable to assign IP addresses after reboot
Hi, every time I reboot or unplug my router to move it, all my devices will disconnect and will have an "unable to assign IP addresses" error. I have 48 devices and all of them will not connect. I wo...
rayjai
Jun 15, 2022Guide
firmware V4.6.8.2 for the router.
I am using a CM600 modem with optimum.
I'm not sure about the distance, but my backhaul is good.
Satellite 1 - 2 is V4.6.8.2
Satellite 3 is V4.6.5.14, it says there's no new firmware for this one.
Jun 16, 2022Guru - Experienced User
What browser are you using? Try a different browser?
What are you seeing when you trying to set an IP address reservation?
