rayjai
Jun 15, 2022Guide
RBR750 unable to assign IP addresses after reboot
Hi, every time I reboot or unplug my router to move it, all my devices will disconnect and will have an "unable to assign IP addresses" error. I have 48 devices and all of them will not connect. I wo...
CrimpOn
Aug 26, 2022Guru - Experienced User
rayjai wrote:
It seems like all my devices and routers are on 192.168.1.xxx
every time I reboot, a conflict happens between the routers and devices.
Please explain what the conflict is.
rayjai
Aug 27, 2022Guide
I think I see the routers are trying to set 192.168.1.250. everytime I reboot all my devices say there is an IP conflict and I can't connect to the wifi.
- raven_auAug 27, 2022Virtuoso
rayjai wrote:I think I see the routers are trying to set 192.168.1.250. everytime I reboot all my devices say there is an IP conflict and I can't connect to the wifi.
The Orbi satellites appear to always start out with a .250 address and if the DHCP server decides to stop allocating addresses they stay at that address. Stupid really as .250 is within the default DHCP allocation range so a conflict is possible.
I set my DHCP range to 2-249 to avoid this possible problem.
- rayjaiAug 29, 2022Guide
Thank you, where do I change the DHCP range? Under Lan setup?
