stevie1037
Feb 07, 2025Aspirant
RBR750 unable to be set up with NBN fibre to the premises
Hi I previously had this working fine with fibre to the node but have changed my provider and I now have fibre to premises as opposed to fibre to the node as I had previously. I have deleted and re...
- Feb 10, 2025
stevie1037 wrote:
It is the V7.2.6.31 which some people have had trouble with 😞
Yes, v.31 hasn't been good for most users.
Should I install a previous version?
Might downgrade the system back to v.21 FW, RBS first, RBR lastly, then factory reset and setup from scratch. Disable the AutoUpdate feature on the RBR to prevent the system from re-updating to v.31. Then setup the system for your configuration and then save off a backup configuration to file for safe keeping.
Also I wonder if you can do a factory reset of the Orbi ?
Can try that as well.
It seems to continue to send the old provider's signal even though it is not connected to it?
The wall unit is a box provided by the National Broadcasting Network here in Oz , they run the fibre network.
It is coonected with a good cable
Might try a 1Gb non managed LAN switch in between the Fiber ONT/Converter unit and the RBR. Something like a GS105 or GS305. Don't connect anything else to this switch.
Feb 07, 2025Guru - Experienced User
Try setting up the RBR using a ethernet connected PC and web browser.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Be sure your using a good quality LAN cable between the modem and router. CAT6A is recommended.
- stevie1037Feb 10, 2025Aspirant
- FURRYe38Feb 10, 2025Guru - Experienced User
- stevie1037Feb 13, 2025Aspirant
OK I finally got it working by resetting the Orbi. It seems the previous providerdetails was conflicting with the setup process . Thanks for your help
