kazankota
Dec 24, 2020Follower
RBR750 Updated Firmware but Satellites didn't update and now don't connect
I was informed to post here (sorry about that) RBR750 Updated Firmware but Satellites didn't update and now don't connect Orbi RBR750 Updated Firmware to V3.2.16.22 but RBS750 Satellit...
Dec 24, 2020Guru - Experienced User
you can manual update them. log into them using their ip address and do a manual update.
if they won't connect back to the router, hardwire into the satellite with a pc/laptop, it should have a default ip address of 192.168.1.250 that you can access it with to update them manually.
- FURRYe38Dec 26, 2020Guru - Experienced User
One problem current is that the v22 fW files have not been posted for manual download yet. :smileyembarrassed:
