lex_won
Jul 05, 2021Aspirant
RBR750 Upload speed
Hi, As titled I am having issues with my upload speed on my Orbi Router. When I test internet speed from the Orbi router admin page I get My internet speed to my modem is 1Gig down and 7...
Jul 05, 2021Guru - Experienced User
- lex_wonJul 05, 2021Aspirant
Thanks for the reply!
The RBR750 router is using firmware version v3.2.18.1
I am not sure what MFR stands for but if it helps the modem is a Bell Home Hub 3000 which is a Sagemcom F@st 5566 modem (http://www.dslreports.com/hardware/Sagemcom-F-st-5566-h4553)
Does that help?
- FURRYe38Jul 06, 2021Guru - Experienced User
What happens if you use the modem as the router with wifi disabled and the Orbi in AP mode?
What wireless and wired devices are you testing with?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- lex_wonJul 06, 2021Aspirant
Thanks for the link!
I'll standardize how im testing my speeds (right now its using the speedtest app on different devices) and then try to isolate the problem more.
My home is approx. 1600 sq ft so not that large and I think the RBS and the RBR are more than 30 ft apart.
I will update here once I do more testing.
