Justini
Sep 11, 2022Guide
RBR750 (V4.6.9.11_2.3.5) vs Telenor IPTV
Ever since most recent firmware, my Telenor IPTV cuts out for a couple of seconds, every 10 minutes. Any known workaround? Anyone else in Norway experience the same? IGMP proxy is disabled.
Sep 11, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- JustiniSep 11, 2022Guide
Orbi router is not connected to any ISP-provided hardware. Connected directly to Ethernet cable which goes to media converter then fibre.
I have not tried a factory reset after the latest firmware, so will try that.
Thanks for the suggestions.
- FURRYe38Sep 11, 2022Guru - Experienced User
What is the brand and model of the media converter? I would power OFF this converter and the Fiber box as well for 1 minute then back ON. Walk thru the setup wizard after you reset the RBR.
- ekhalilSep 11, 2022MasterI think this issue is similar to this one: https://community.netgear.com/t5/Orbi/Orbi-AC3000-RBR50-and-IPTV-via-Telenor/td-p/1694668
