Justini
Sep 11, 2022Guide
RBR750 (V4.6.9.11_2.3.5) vs Telenor IPTV
Ever since most recent firmware, my Telenor IPTV cuts out for a couple of seconds, every 10 minutes. Any known workaround? Anyone else in Norway experience the same? IGMP proxy is disabled.
Sep 11, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Justini
Sep 11, 2022Guide
Orbi router is not connected to any ISP-provided hardware. Connected directly to Ethernet cable which goes to media converter then fibre.
I have not tried a factory reset after the latest firmware, so will try that.
Thanks for the suggestions.
- FURRYe38Sep 11, 2022Guru - Experienced User
What is the brand and model of the media converter? I would power OFF this converter and the Fiber box as well for 1 minute then back ON. Walk thru the setup wizard after you reset the RBR.
- ekhalilSep 11, 2022MasterI think this issue is similar to this one: https://community.netgear.com/t5/Orbi/Orbi-AC3000-RBR50-and-IPTV-via-Telenor/td-p/1694668
- JustiniSep 12, 2022Guide
Yes, similar.
It was working with previous firmware, but just seems to have become a problem again with the latest release.
Media converter is Alcatel-Lucent model I-010G-S ONT rev 1.1
Powered it off for some minutes. Powered on and factory reset my Orbi RBR750
Ran through the initial configuration and unticked "disable IGMP proxying".
Same problem.
All IPTV features work, but short signal drop every 10 minutes.
- FURRYe38Sep 12, 2022Guru - Experienced User
What FW version prior was this working on?
