Stevenpost
Dec 03, 2021Follower
RBR750 w/ 2 satellites dropping internet.
I have RBR750 w/ 2 satellites that had worked flawlessly until recently. I think it began with the latest firmware update, my wife thinks it was before that. We get continuous dropped internet on all ...
Dec 03, 2021Guru - Experienced User
FW same version on RBS as whats loaded on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Turn off and unplug modem.
Turn on RBS wait for them to connect.
Try turning OFF 1 RBS while running just one RBS.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
