codynet
Oct 17, 2021Aspirant
RBR750 WIFI - fast upload but slow download
I just purchased an RBR750/RBS750 and have it on latest firmware (V4.6.5.14_2.0.54). I have the router hooked up to my gigabit ethernet. When I run speedtest (speedtest.net- not the one built into th...
Oct 17, 2021Guru - Experienced User
Whats the wireless device your speed testing with?
Whats the connection rate between this wireless device and the RBR?
codynet
Oct 26, 2021Aspirant
Any ideas?
- FURRYe38Oct 27, 2021Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
Have you disabled AX mode on 2.4Ghz?
Also try using manual channels 11 and 48.
Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a full facory reset and setup from scratch been performed since last update?
Others have mentioned a reset has helped them. You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579- codynetOct 31, 2021Aspirant
2000sqft.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Tested with more and less than 30 ft. No difference.
No close neighbors on 5GHz.
Yes. I noticed after changing this my PCs will no longer connect on 5GHz. What could cause that? I rolled it back and noticed my computers will still only connect over 2.4GHz.
The only 5GHz channels I have are 36, 40, 44, 48.
No impact.
Yes.
