Mataluir
Apr 01, 2021Aspirant
RBR750 wifi 6 issues
RBR750: None of my televisions, fire sticks, or Roki support wifi 6 WPA3 Had to go to WPA2 Performance no better than the orbi ac2200 system.... Help
Apr 01, 2021Guru - Experienced User
The main bottleneck in systems like these are the device you're using and not the router/satellite. If you're device aren't wireless AX you won't see much benefit. where you will see benefit is in concurrent usage. (multiple devices being used at the same time)
