Mataluir
Apr 01, 2021Aspirant
RBR750 wifi 6 issues
RBR750: None of my televisions, fire sticks, or Roki support wifi 6 WPA3 Had to go to WPA2 Performance no better than the orbi ac2200 system.... Help
Apr 01, 2021Guru - Experienced User
The main bottleneck in systems like these are the device you're using and not the router/satellite. If you're device aren't wireless AX you won't see much benefit. where you will see benefit is in concurrent usage. (multiple devices being used at the same time)
Mataluir
Okay, so This will still have better performance overall because it will handle a lot more devices. Is this correct?
Thanks for your prompt attention in responding to my issue.
Much appreciated.
Much appreciated.
- plemansApr 01, 2021Guru - Experienced User
This is a good article to read on the downfalls and benefits of wifi 6 and how it works with current generation products.
Not a long read but educational.
- FURRYe38Apr 01, 2021Guru - Experienced User
Couple of other articles to review:
Something Orbi AX doesn't have. :smileywink:
