DrInfoman
Sep 29, 2021Aspirant
RBR750 WiFi 6 Mesh - Switches From Ethernet to WiFi and Back Several Times A Day
I have an ethernet going from the router (RBR753 - 750 and two satellites) to my laptop, and all had been fine for a while. Now, in the last 2 day, it's constantly dropping the ethernet and goes to ...
- Sep 30, 2021
Hi!
No LAN switch in-between, using CAT7 cables.
But I think I have resolved it. The cable going from the router to my laptop - I don't think it was connected "100%" to the laptop - only "partially" (wasn't "clicked in") - removed it and redid it, and so far, no hiccups.
Thanks!
Andy
DrInfoman
Sep 30, 2021Aspirant
Hi!
Thanks!
Andy
Sep 30, 2021Guru - Experienced User
Glad that was all.
Please mark your thread as solved so others will know.
Enjoy.
