San2021
Mar 02, 2024Initiate
RBR750 wifi DHCP issues after reboot
RBR750 with 2 satellites have issues with DHCP server where after a reboot devices won't obtain an IP address. Workaround: Every time you have to login locally(via LAN) to router and change DHCP Pool...
microchip8
Mar 02, 2024Master
Have you tried factory reset & reconfig from scratch?
San2021
Mar 03, 2024Initiate
1. Tried factory reset and config from scratch multiple times
2. Upgrade firmware to the latest and then factory reset
3. Inspect the logs on Orbi(RBR750) and pcap on the client side and shows that DHCP lease not being handed by Orbi.
4. So, far every time I have to choose unique(previously not used) DHCP scope to make SSID work.
