carpeDiem3
Jun 08, 2022Aspirant
RBR750 wifi drops all the time every 2 minutes or less
I am using 2 Orbi RBR750's with a total of 4 satellites, both of the RBR750s are used as access points connected to separate ports on my Firewalla. with separate IP ranges and isolated from each othe...
Jun 08, 2022Guru - Experienced User
carpeDiem3 wrote:
I am using 2 Orbi RBR750's with a total of 4 satellites, both of the RBR750s are used as access points connected to separate ports on my Firewalla. with separate IP ranges and isolated from each other. the 5 g channels are set separate from each other , one is 36 and the other 48, 2.4 is set to auto. < channel 1 should be set on one RBR and channel 11 should be set on the 2nd RBR. So I use one with 3 satellites for my home and one with one satellite for my guest network. ( all in the same space)
Ever since I setup the second one for the guest setup, it constantly drops the Wi-Fi network, I mean every minute.
Whats the size of this home? Sq ft.
Having too much wifi signal running can cause problems:
What is the distance between the router and đĄ satellite(s)? 30 feet or more is recommended in between RBR and RBSđĄ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite đĄYou also may need to turn down the power out put of the 2nd system to 25% and maybe set the 1st system to 50%.
home network runs on V4.6.8.2 (pushed update from Netgear due to the update problem)
guest network runs on V4.6.5.14 and I don't know where to download the newer version.
Guest Network would not be on or should be on a different FW version. AL RBR and RBS should be on same version FW level.
Has anyone seen this problem before or has an idea on how to fix this ? No. I can run two Orbi systems. However channels, distances and transmit power need to be configured correctly.
carpeDiem3
Jun 09, 2022Aspirant
What's
the size of this home? Sq ft. Having too much wifi signal running can cause problems:
it is about 5500 sqft serving 2 living spaces
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
they all are 20 to 30 feet apart depending on the obstacles in the way , but its the router that is disconnecting , so the satellite is not even in the picture
they are running independent on separate channels
I wish I could but Netgear pulled V4.6.8.2 from their side (due to issues) prior to me installing the second network , and it specifically states not to downgrade from this version
I am almost certain that I configured it correctly , still the issue persists.
- FURRYe38Jun 09, 2022Guru - Experienced User
- carpeDiem3Jun 09, 2022Aspirant
@ FURRYe38
Its a firewalla Gold
Firewalla Gold: Multi-Gigabit Cyber Security Firewall & Router Protect | Firewalla
- DarkNetJun 09, 2022Apprentice
Thanks. Yes that explains it. I have a pfSense firewall (your firewalla looks nice too) and use my single RBR850 in AP mode and use the guest SSID for IoT devices in the house. I have 2 RBSâs. You are correct that the guest SSID IPs donât show up in the Router/FW and you canât write rules for or manage that segment. The guest SSID is supposed to be separated from the regular wifi (and LAN) and, for me anyway, thatâs all I need.
Did you turn OFF the regular SSID wifi in your 2nd RBR as well as turn OFF the guest SSID wifi in your 1st RBR?
