carpeDiem3
Jun 08, 2022Aspirant
RBR750 wifi drops all the time every 2 minutes or less
I am using 2 Orbi RBR750's with a total of 4 satellites, both of the RBR750s are used as access points connected to separate ports on my Firewalla. with separate IP ranges and isolated from each othe...
DarkNet
Jun 09, 2022Apprentice
Thanks. Yes that explains it. I have a pfSense firewall (your firewalla looks nice too) and use my single RBR850 in AP mode and use the guest SSID for IoT devices in the house. I have 2 RBS’s. You are correct that the guest SSID IPs don’t show up in the Router/FW and you can’t write rules for or manage that segment. The guest SSID is supposed to be separated from the regular wifi (and LAN) and, for me anyway, that’s all I need.
Did you turn OFF the regular SSID wifi in your 2nd RBR as well as turn OFF the guest SSID wifi in your 1st RBR?
carpeDiem3
Jun 09, 2022Aspirant
Yeah I want control over what goes in and out of the network , even on the guest Wi-Fi,, I also need to have rules depending on who you are when you log into guest. so I can isolate that traffic.
I did turn off Guest SSID on the primary, what would turning OFF the regular SSID wifi in your 2nd RBR do >?
the second SSID has guest disabled the same as the primary and runs trough the FW on a segregated network outbound. So the second SSID broadcasts for Guest users to connect to only the internet ,,,,, (if) I move them out of Quarantine.
- DarkNetJun 09, 2022Apprentice
Yes you’re right. For a sec I was thinking you used the guest SSID on the 2nd RBR. You’re using the primary wifi on both.
