howToFixMyWifi
Dec 04, 2021Aspirant
RBR750 WIFI Issue on IOS devices
Hi, I have the Orbi AX4200/RBR753, and seeking for help on how to resolve the wifi issue on IOS devices. Setup: 1 * router/RBR750 in Basement on the left side of the house 1 * satellite/RBS750...
- Dec 06, 2021
Thanks, I thought about moving AP2 to somewhere else.....but but but, when I am moving around while the iperf testing is still running, i do see that I am always conneted to the closest AP by verifying on the router page, and I can tell that speed is going down when I am moving away, and coming back to full when i am at another AP.
Look, IF the issue is it does not roam to another AP, I get it, 2 AP are too close. but I cam roam fine from AP to AP... the issue is it stuck on connectivity when I am at AP2..... and and and, does not happen all the time, i tried again last night and the night before, man, I did not have issues, aka cannot reproduce.....
my full time job is NETWORK ENGINEER, but on enterprise products, not on consumer equipments like this....LOL, I dont have the backend access to find out the root cause.....
howToFixMyWifi
Dec 06, 2021Aspirant
Somehow there are some bad paste, I can not edit it...
here is the clean version:
Hi,
Setup:
1 * satellite/RBS750 on floor 1, right side of house, with cat6 wire connected to the router.
1 * satellite/RBS750 on floor 2, right side of house, basically the same position as the satellite on floor1. with WIFI 5G2 used as backhaul
all 3 devices are on the latest firmware V4.6.5.14.
Issue:
I am using my iPhone 11, and iPad Pro 11 2021 in the basement watching movie from NAS wire connected to router, and going to floor 2. I can no longer connect to the NAS, can not ping router ip, can not ping nas ip on both iphone and ipad. in the meanwhile windows laptop works fine. from router gui, i can see that iphone, ipad, windows laptop are connected to floor2 satellite.
Since iphone/ipad can not ping anything, and I can not open any page, but wifi is connected (also verified on the router gui page showing they are on ) satellite floor 2. it would work again if I
- turn off wifi on iphone/ipad, and turn it back on
- go to basement again, and come back, aka roam back to router and roam back to satellite 2.
This issue does not happen everytime i go from basement to floor 2, it happens once a while.
Seeking for help of how to resolve this? (I CAN NOT run another wire to the floor 2).
options on my mind:
- remove satellite2, use satellite1 only.
- or reposition satellite2 to somewhere, however I dont see where else needs it....
- disable Daisy chain? however I dont see this possible on RBR750
Thanks a lot!
- FURRYe38Dec 06, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Check with Apple support about this as well if other devices work and can see the NAS.
- howToFixMyWifiDec 06, 2021Aspirant
home is 4000 SQFT total including basement.
router to AP1 --> cat 6 cable- about 20M long.
AP2 to AP1 --> 5G2 backhaul, about 5 meter apart.
My guess is AP2 is connected to AP1, not to the router, as router is far away than the AP1.
so to make the problem more clear that is NOT the speed that is slow, it is IT CAN NOT ACCESS/PING when connected.
