prongs_386
Jan 12, 2023Follower
RBR750 Wifi Issues
For a while my partner and I have been experiencing intermittent poor internet access. Recently I monitored performance counters to find that about 4% of tcp segments are being retransmitted. Is this...
michaelkenward
Jan 13, 2023Guru - Experienced User
The RBR750 is an Orbi router and not one of the SMART Wi-Fi, General and Legacy Routers covered in this section.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
