nickbeamon
Aug 27, 2022Aspirant
RBR750 wifi not supplying internet to devices connected to it. Odd Problem
RBR750 Firmware V4.6.8.2_2.1.9 2 Satellites RBS750 I just factory reset last night and that did not fix any issues Ok this is frustrating the heck out of me. This has been happening for the...
nickbeamon
Aug 29, 2022Aspirant
looks like a nail in the coffin on this one. I registered the equipment on 5-25-
2021 so i lost all the warranty on 8-25-2022
Aug 29, 2022Guru
For that size of home, you really only need the RBR and 1 RBS.
I would turn OFF one RBS and see what happens. Or turn down the power on the RBR from 100% to 25%.
Have you updated FW yet?
- nickbeamonAug 29, 2022Aspirant
I have tried running a full day on just the RBR and 1 RBS still have same issues with wireless devices with no internet
Setting the power range down still had same problems
Firmware has been upgraded with same issues after.
- FURRYe38Aug 29, 2022Guru
Possible you may have a faulty Orbi system. I would contacf NG support and ask about another Orbi system as a RMA to see if another system solves this problem:
https://my.netgear.com/support/contact.aspx
If another system does same thing, I would look at the ISP services and try replacing the ISP modem.
well I would contact support but when putting in the S/N this is what i get from their website
Standard Product Warranty
Hardware-Expired On 2022-05-25
Chat Support-Expired On 2021-08-23
Phone Support-Expired On 2021-08-23
Email Support-Expired On 2021-08-23
Power Supply-Expired On 2022-05-25
Accessories-Expired On 2022-05-25
