nickbeamon
Aug 27, 2022Aspirant
RBR750 wifi not supplying internet to devices connected to it. Odd Problem
RBR750 Firmware V4.6.8.2_2.1.9 2 Satellites RBS750 I just factory reset last night and that did not fix any issues Ok this is frustrating the heck out of me. This has been happening for the...
Aug 29, 2022Guru - Experienced User
Possible you may have a faulty Orbi system. I would contacf NG support and ask about another Orbi system as a RMA to see if another system solves this problem:
https://my.netgear.com/support/contact.aspx
If another system does same thing, I would look at the ISP services and try replacing the ISP modem.
nickbeamon
Aug 29, 2022Aspirant
"If another system does same thing, I would look at the ISP services and try replacing the ISP modem."
With the issues that have been coming up.
- Devices wireless connected to the RBSs losing internet while devices connected to RBR still having internet.
- The exact opposite devices wireless connected to RBR no internet while devices connected to RBS are fine.
- All wireless devices connected with no internet and then plugging hard lined into RBR with ethernet connection and internet working
- I have unplugged the Ethernet cable from the back of the RBR and plugged it into a laptop during one of the no internet messages and right off the modem the laptop was able to resolve IP address and internet connection.
- All devices connected have an IP address but when problem occurs you can release and renew in command prompt get a fresh ip and still not be able to ping the default gateway/RBR
- no difference in pinging websites names vs their ip addresses so not DNS related
- Firmware updated to newest with no change in issues
