752User's avatar
752User
RBR750 wifi speed stuck at 20 Mbps after firmware update
I have had the 752 series (router+2 satellites) for over a year - no issues at all. I have a gig speed fibre connection and was consistently getting 350+ on my wifi in various parts of the house ...
  • FURRYe38's avatar
    Whats the model # of the ONT?
    Do a backup configuration to file pre reset:
    Once you have this, I would reset the RBS and RBR, power OFF for a minute then back ON. I would set up only the RBR first, once the setup wizard is completed. Run some speed test both wired and wireless BEFORE applying the backup config file. Don't enable Armor, Access Controls, SPC or Traffic meter. Check speeds first, then apply the backup config and setup the RBS.
