752User
Nov 09, 2021Aspirant
RBR750 wifi speed stuck at 20 Mbps after firmware update
I have had the 752 series (router+2 satellites) for over a year - no issues at all. I have a gig speed fibre connection and was consistently getting 350+ on my wifi in various parts of the house ...
- Nov 09, 2021
Whats the model # of the ONT?
Do a backup configuration to file pre reset:
Once you have this, I would reset the RBS and RBR, power OFF for a minute then back ON. I would set up only the RBR first, once the setup wizard is completed. Run some speed test both wired and wireless BEFORE applying the backup config file. Don't enable Armor, Access Controls, SPC or Traffic meter. Check speeds first, then apply the backup config and setup the RBS.
752User
Thank you - i have tried powercycling, to no avail. No modem, just ONT (Verizon Fios).
As for factory reset, i am wary (too many settings to re-do), but also don't have the time right now.
Should i be able to retrieve settings from backup after factory reset? if not, that's a big enough reason for me to think twice.
Nov 09, 2021Guru - Experienced User
- 752UserNov 09, 2021Aspirant
Thank you again- i am not sure of my ONT model - not at the house now, so will find soon.
Sounds simple, even if time taking. Will try over the weekend.
Thanks again. Will update in a few days.
- FURRYe38Nov 09, 2021Guru - Experienced User
đ
- 752UserDec 15, 2021Aspirant
Finally - the reset worked!!! Thanks FURRYe38
Quick note - i reset everything once, it was great. Then i restored settings from before the reset (i didnt want to go through the whole process), and it broke again. Not sure what was in the settings (didn't think anything firmware-related was in there).
Either way, another reset and manual update later, i'm back. Now i just have to figure out how to stop it from auto-updates.
