andrewka
Jan 06, 2024Aspirant
RBR750 WiFi stop working after firmware update
Hi. After update the firmware on RBR750 WiFi stop working absolutely. It's not advertising the WiFi network. Also I tried to put ssid manually but had the same result. I can get access to router only...
andrewka
Jan 16, 2024Aspirant
You read my mind. I also think to buy another one RBR and make deep analysis of booting log and compare the flash memory and memory mapping. Thanks for advise.
Jan 16, 2024Guru - Experienced User
If you can get into the serial console using the serial port to USB, would have more access to maybe finding out something or maybe getting the RBR back into operation.
Good Luck.
