daddio5's avatar
daddio5
Tutor
Mar 22, 2022
RBR750 WiFi6 Connection
I recently purchased an HP Envy Laptop with a WiFi6 (802.11ax) card. It appears that when I'm connected to my Orbi mesh system with WiFi6, the laptop is only running at WiFi5. How can I establish a W...
  • plemans's avatar
    Mar 22, 2022
    a couple things off that.
    You're connected to the 2.4ghz and not 5ghz. The orbi's do bandsteering and move devices between the 2.4ghz and the 5ghz based on their own protocol. I think in windows theres an option in the device manager for that wifi card to select "prefer 5ghz"
    You won't "show" that your connected to wifi 6 routers/devices but its based on link speed. And most 2.4ghz routers use 20/40hz coexistence (neighbor friendly) so its actually a pretty good speed if you're connecting on that with a 2x2 device.
