Dolphins
Dec 19, 2021Aspirant
RBR750 will not connect solid amber power Led
Trying to set up the ORBI Router for the first time, the router when plugged into the power supply the power led light stays in a solid amber state. I have tried swapping the power supply with the sat...
michaelkenward
Dec 20, 2021Guru - Experienced User
Sounds like it is stuck at booting.
If a reset doesn't unstuck it, then it sounds like it is dead on arrival. Bet take it back to whoever supplied the thing.
