Dolphins
Dec 19, 2021Aspirant
RBR750 will not connect solid amber power Led
Trying to set up the ORBI Router for the first time, the router when plugged into the power supply the power led light stays in a solid amber state. I have tried swapping the power supply with the sat...
Dec 21, 2021Guru - Experienced User
Any progress on this?
Dolphins wrote:
Trying to set up the ORBI Router for the first time, the router when plugged into the power supply the power led light stays in a solid amber state. I have tried swapping the power supply with the satellite unit no change. Both power supplies power up the satellite unit.
I have tried utilizing the ORBI app to set up but the router is not sending out a WiFi network.
