TFAD
Dec 30, 2023Aspirant
RBR750 will not connect to Starlink
I know it’s been a while since the last post in this thread but I’m having a similar problem and the solution here hasn’t work.
Our Starlink version is ‘Round Dishy’ with UTR-201 router.
Dec 30, 2023Guru - Experienced User
The ISP has some ethernet adapter that maybe needed. Something you'll need to ask the ISP about regarding it and getting services connected properly to the Orbi system. https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Orbi-RBKE-963-and-Starlink-again/m-p/2316943#M45546
TFAD
Dec 31, 2023Aspirant
Thanks. The Starlink V1 router has an Ethernet port so doesn’t need the adapter, but I have described the problem to Starlink and they are sending a replacement unit. Have ordered the adapter with it to connect to Orbi, so hopefully that will work.
