rascom-it's avatar
Nov 13, 2020
RBR750 will not sync
I have purchased an AX4200 set for one of my customers.  As they already have a pre-configured Netgear router in place, we are putting the Orbi Router unit into AP mode so that the Orbi Satellites can connect to it.
However despite having setup a couple of other Orbi kits in the past, these units do not seem to want to sync properly.
I have spoken to Netgear Technical Support who are not sure of the problem.
What I have done so far:
Reset Orbi router and satellites to factory defaults (3 times!).
Logged into the Orbi router and it seems both satellites.
Configured the Orbi router for AP mode (with DHCP enabled).  Rebooted the Orbi router.
If they remain hard-wired into the Orbi router, the satellites are detected on the network and can be accessed wirelessly.
As soon as the Ethernet cable is removed, the Satellites drop offline (front LED goes magenta).
I have tried sync'ing them to the router using the SYNC button on the back of each of the units - the front LED pulses white for a few minutes but then goes magenta again on the satellites.  If I log onto the Orbi router via my Internet browser and try to add a new satellite, I press the SYNC button on the satellite and click the SYNC button on the browser window  After a few minutes it reported "Satellite sync failed".
Am at my wits end now and no idea why sync'ing is not working.  Is anyone else having these problems?  Clearly as the units sync up under their factory default configuration there is not a problem with the hardware itself so why will it not work when the router is in AP mode?
  • Do you have ethernet networking cabling in wall between where the XR router is and the remote locations where the RBS are located?
    Seems that the RBS may not be getting a IP address from the XR router thru the RBR in AP mode.
    Are you using Dynamtic or Static AP mode configuration on the RBR?
    Ive always used a static IP address on my RBR in AP mode, i.e. 192.168.#.85 with the subnet mask, gateway and DNS input as well. I set my XR450 for a default IP address pool of 192.168.#.100 thru .200. This gives me room for static IP addressed devices on either side of this pool.
    • rascom-it's avatar
      rascom-it
      Tutor
      Latest firmware is on all units (V3.2.16.6_1.4.4).
      I originaly tried these through a Netgear D6400 router but have also tried them on my home network which has an XR500 on it.
      Cabled directly into each other, they work fine but we won't have backhaul capabiliities were they will eventually be going so will only ever be able to connect wirelessly.
      Hope that helps.
      • FURRYe38's avatar
        What mode is the modem working in? Bridged would be preferred then use the XR500 as your main host router with it's wifi disabled, then configure the RBR for AP mode. I would first wirelessly connect the RBS to the RBR in AP mode.
        Setting up AP mode:
        https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        When you get the RBR fully setup for AP mode. Bring one of the RBS in to the same room as the RBR or near the RBR, say 10 feet. Let it wirelessly sync. Once it's sinced and BLUE LED is seen in front, connect it to the back of the RBR with a LAN cable. Be sure to tuse a good quality LAN cable. CAT6 is recommended.
        Does the RBS sync via ethernet at this location with the RBR?
        I've had my Orbi AX connected to my XR450 many times in AP mode, it should work well.
