rascom-it's avatar
Nov 13, 2020
RBR750 will not sync
I have purchased an AX4200 set for one of my customers.  As they already have a pre-configured Netgear router in place, we are putting the Orbi Router unit into AP mode so that the Orbi Satellites ca...
  • FURRYe38's avatar
    Do you have ethernet networking cabling in wall between where the XR router is and the remote locations where the RBS are located?
    Seems that the RBS may not be getting a IP address from the XR router thru the RBR in AP mode.
    Are you using Dynamtic or Static AP mode configuration on the RBR?
    Ive always used a static IP address on my RBR in AP mode, i.e. 192.168.#.85 with the subnet mask, gateway and DNS input as well. I set my XR450 for a default IP address pool of 192.168.#.100 thru .200. This gives me room for static IP addressed devices on either side of this pool.
