Toppingphoto
Nov 18, 2024Aspirant
RBR750 wired connection is slower than wifi
I don't understand what is going on. I have spectrum internet and the download speed test going into my router is 490 - 500mbps. The wifi connection on my phone - laptop - and iMac is around 400mbps....
Toppingphoto
No the problem is consistent with each computer I try. Anything done wireless is fat around 400mbps. and anything done wired is less than 95mbps. I even tried hooking direct out of the orbi without a switch or anything to interfere. That method got me the 95mbps. Seems like an output problem with the orbi
Nov 18, 2024Guru - Experienced User
Check with a different wired PC to see if same thing happens.
Check the connect rate on the PC and on the RBRs web page under Advanced/Show Stats tab to see if the connection rate on the LAN port on the RBR shows 100Mpbs or 1000Mpbs. Should be 1000Mbps.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
