djdodge
Jul 17, 2022Follower
RBR750 wireless not working
I have the same issue and have been for about 6 months. Everything works fine and then a device can see the main Wifi but no internet connection. Switch to guest Wifi and it works fine, try and swi...
Jul 18, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
You might update FW to v.5 as well and see if anything changes:
AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
