wefjeber
Nov 11, 2024Aspirant
RBR750 with 2 RBS750 ethernet backhaul not working
Gateway-> RBR750> 2 RBs750's> switches>other random devices. I have had this system working for 2 years without an issue. The RBR750 is connected directly to the two satellites by ethernet. A...
CrimpOn
Nov 11, 2024Guru - Experienced User
When the firmware was updated, were the two satellites updated first, and then the router (last)?
There have been (to many to count) reports on the forum about problems when the router and satellites are not on the same firmware version.
If they are not, the (ugly) solution is to
- Manually reload the previous firmware on the router.
- Update each satellite.
- Update the router.
