wefjeber
Nov 11, 2024Aspirant
RBR750 with 2 RBS750 ethernet backhaul not working
Gateway-> RBR750> 2 RBs750's> switches>other random devices. I have had this system working for 2 years without an issue. The RBR750 is connected directly to the two satellites by ethernet. A...
wefjeber
Thanks for the replies. I did not update the RBS first (rookie mistake). I did the auto update and it did the RBR only. I then manually updated the RBS units. I subsequently re-checked the firmware and all were showing v .31. I then tried re-booting a bunch of different ways with no luck. I didnt back anything up (again rookie mistake).
So will this work?
Detach RBR from internet and factory reset (also disable auto update)
Do I also Factory reset the 2 RBS?
If I do factory reset the 2 RBS. Do I update those first, then bring RBR up to date?
If I don't factory reset the 2 RBS, do I just update the RBR? Should I unplug the 2 RBS while I'm updating RBR?
CrimpOn
Nov 11, 2024Guru - Experienced User
You could connect to the satellites when Attached Devices said they were 'Disconnected'?
Might try temporarily bringing them to the same room as the router and see if they will connect over WiFi.
