JDSeyCO
Jul 21, 2021Follower
RBR750 with 2 RBS750 satellites
I have the AX4200 with V3.2.18.1 for firmware. Is this the latest firmware? Should I be on firmware 4.6.3.7? I never receive update messages through email regarding updates to firmware. What a...
Jul 21, 2021Guru - Experienced User
You can be on v3 or you can upgrade to v4:
All versions of FW prior to v4 do not have any parental controls. Something that was annouced Orbi AX would have in a future date and for the 7 series, arrrived in v4. Some users many not need parental controls so you may take this into account as well.
It's up to you if you want to update or not. Seen information that users can't revert back to older versions of FW after v4 is applied, so were still looking into this.
NG is kind of sporadic on FW update emails and not consistant. I recommend checking here in the forums for FW updates and user experiences and NG download support site as well for FW updates and information for gaining good information.
- southpawdf16Sep 15, 2021Aspirant
I have an RBR 750 with 2 satellites. I am on the Orbi Admin page for the network, When I try to check for new firmware it is showing there is no new firmware available. My current firmware version is V4.6.3.16, and I know there is a new version available on the NetGear website (V4.6.3.7). Why is it not showing the newer version when I click check? This has happened to me before, and I have had to manually update the firmware, even though they don't recommend it. See below image for reference. Thank you in advance!
- FURRYe38Sep 15, 2021Guru - Experienced User
If your current version is V4.6.3.16 then there is nothing newer then that. v16 just officially released today. This supersedes v7.
