Dannyboy402
Aug 07, 2021Aspirant
RBR750 with Firmware V4.6.3.7_2.0.49 not working anymore
Anyone else have issues after updating their RBR750? I updated to V4.6.3.7_2.0.49 and I no longer have internet access through my orbi setup. I returned my previous RBR750 thinking it was no longer working and got a replacement. I setup the new orbi system and it was working until I performed the firmware update. My ISP is centurylink fiber and I know I have the right PPPoE credentials put in because it was working flawlessly before the firmware update.
- Dannyboy402Aspirant
Nevermind! After the update the VLAN was switched off and I re-enabled it and it's now working.... Ughhhh
Please mark your thread as solved so others will know.
Enjoy.
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
