OrbiStillDead
Apr 03, 2022Tutor
RBR750 with RBR50 in AP Mode
Would that pairing work? I was thinking of getting the RBR750 on ebay and using my current RBR50 as the satellite. The 750 is wifi6 and the 50 is only wifi5 so idk if they're compatible or not.
OrbiStillDead
Apr 04, 2022Tutor
I do have 1 RBS50 and my internet speed is 400 down 20 up. My gf will also be upgrading her phone as well. My RBK50 system is 4 years old it's time for an upgrade.
Apr 04, 2022Guru - Experienced User
The speeds you get aren't enough for you for two people?
Whats not working out for you with the ISP speed package?
