Ra21V12eN
Oct 26, 2021Tutor
RBR750 with Regular Guest WiFi Drops
Thought I had posted this within this forum but realized after another member posted it went to the main forum. I have an RBR750 with 2 satellites connected to Comcast via a self owned Netgear ca...
Oct 31, 2021Guru - Experienced User
So if you move the devices from the guest network to the main network, they work ok?
ant
Nov 02, 2021Prodigy
Yes for me.
FURRYe38 wrote:So if you move the devices from the guest network to the main network, they work ok?
- Mikey94025Nov 02, 2021Hero
One random experiment to try is to turn off all but one satellite. For a long time now, my RBR850 system incurs mysterious periodic satellite disconnects if I power on on the 2nd or 3rd satellite. I've since given up trying to resolve it and just run with one satellite. While this is a different symptom than you, it's one more variable to try and eliminate.
