bigbusa
Mar 25, 2021Follower
rbr750 won't allow my 2.4ghz gadgets to connect - annoyed - help?
Orbi has worked well for whole house wifi coverage but it's been a royal PITA for my 2.4ghz cameras. I have a ring doorbell that won't connect well enough to allow "live view". I called RING and the...
Mikey94025
Mar 25, 2021Hero
It won't help with setup apps that require 2.4Ghz, but to improve compatibility of your new AX system with older 2.4 wireless devices try these settings that worked for me:
- Go to orbilogin.com in a web browser to access the Orbi admin site, Advanced tab, Advanced / Wireless Settings. Set CTS/RTS Threshold to 2347 for both 2.4Ghz and 5Ghz bands.
- If that doesn't solve your compatibility issues then in Advanced tab, Setup / Wireless Setup, uncheck AX Mode for 2.4Ghz band (only).
