bigbusa
Mar 25, 2021Follower
rbr750 won't allow my 2.4ghz gadgets to connect - annoyed - help?
Orbi has worked well for whole house wifi coverage but it's been a royal PITA for my 2.4ghz cameras. I have a ring doorbell that won't connect well enough to allow "live view". I called RING and the...
Macrich
Mar 31, 2021Tutor
I had the same problem setting up security cameras with Orbi. What worked was turning off 5GHz radio until they were set up, then turning it back on. To do this log into your Orbi at orbilogin.com and go to Basic, Wireless and toggle off 5 GHz.
Mar 31, 2021Guru - Experienced User
Something that isn't supported on Orbi AX.
Macrich wrote:I had the same problem setting up security cameras with Orbi. What worked was turning off 5GHz radio until they were set up, then turning it back on. To do this log into your Orbi at orbilogin.com and go to Basic, Wireless and toggle off 5 GHz.
