helpmeplsdudes
Mar 31, 2025Aspirant
RBR750 Won't let some services like Netflix through
Hello, As of yesterday, my orbi which has worked great for 5 years suddenly won't allow certain services such as Netflix or my work VPN but works for other things such as browsing. Netflix & Max ...
- Mar 31, 2025
Thank you for the help, did a factory reset and it's back to normal, cheers 🙂
Mar 31, 2025Guru - Experienced User
What devices are you using to connect to the Orbi system for VPN and Netflix?
helpmeplsdudes
- FURRYe38Apr 01, 2025Guru - Experienced User
Is this with newer FW loaded?
