Haug1
Apr 27, 2022Aspirant
RBR750 Wont open some internet sites and apps
Some internet sites and some apps on iPhone wont open trough RBR750 Router. It has been working perfectly for some time, but now all connected devises have the same problem on the same internet pages...
- Apr 28, 2022
Checked with my supplier and they confirmed my modem was on bridge mode.
Tried restarting my system as described, without any difference. Still the same sites and apps didn't connect properly to internet.
Performed a factory reset on my system and everything is now up working properly. Not sure what made me unable to connect to some internet sites, but everything is now good.
Thanks for your assistance
Apr 27, 2022Guru - Experienced User
Be sure to disable WiFi Private Address feature on the iphone...
- Haug1Apr 27, 2022Aspirant
Currently running FW V4.6.8.2, the same on the satellites.
I believe it is a Zyxel FMG-3542 that is provided by my TV & internet provider. This is currently in bridge mode.I have tested disable WiFi private address on the iphone. Dont believe the issue is there as all devices have the same issue on the same sites. This is Samsung mobile, PC, ipad, iPhone etc.
- FURRYe38Apr 27, 2022Guru - Experienced User
You sure the modem is in bridge mode?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- Haug1Apr 28, 2022Aspirant
