fdgboy
Nov 01, 2020Follower
rbr750 working, but now have two wifi networks of the same name, should I rename the old wifi?
I've just set up my rbr750 network. Now I have two wifi networks with the same name. Should I change the name of my original wifi network? This would make it easier to tell the difference between ...
Nov 02, 2020Guru - Experienced User
Turn OFF the old wifi router and just use the new Orbi system using the same SSID name and PW you have been using.
